Re: metric hardware for 1977 Pinto
Ron Brown /
David,
I am sure you can get wheel nuts at the moped junkyard or moped warehouse, see the resources section.
Having said that, before you give up, try a bicycle shop and do not assume this is a metric thread. Many older bicycle fasteners used a standard "cycle thread" which is 26 tthreads per inch regardless of diameter. This is very close to a 1.0 mm pitch but different enough to screw up threads if you are wrong, so take the wheel with you. You can also try a local motorcycle shop if the bicycle shop fails.
Ron
  metric hardware for 1977 PintoTopic by: David David 07/24/01 03:05PM
  Re: metric hardware for 1977 PintoRe: Ron Brown Ron Brown 07/24/01 03:22PM
  Re: metric hardware for 1977 PintoRe: Brian Brian 07/24/01 03:58PM
  Did you try a good hardware store? nmRe: Fred Fred 07/24/01 06:21PM
  Re: Did you try a good hardware store? nmRe: Ron Brown Ron Brown 07/24/01 07:45PM
  OK... a REALLY good hardware store...nmRe: Fred Fred 07/25/01 01:33AM
  Re: Did you try a good hardware store? nmRe: Jim C. Jim C. 07/24/01 11:51PM
