Re: PROBLEM WITH PUCH
don-ohio /
Hi,Tom! I did that once and even with sealed rear bearings,I had reversed a washer which then pressed on the bearing when tightened.Are you sure the brake return spring is pushing the arm back where it won't hold a little tension on the shoe against the drum?With drop-in ball bearings,you really have to watch that all are in there,and leave them a little loose rather than tight.BYE!
  PROBLEM WITH PUCHTopic by: tom k. tom k. 07/21/01 11:13PM
  Re: PROBLEM WITH PUCHRe: don-ohio don-ohio 07/22/01 08:49AM
  Re: PROBLEM WITH PUCHRe: PM PM 07/22/01 11:53AM
