It all started when I was cleaning the rear wheel of my 1978 puch maxi sport. I put everything back together exactly like I
PROBLEM WITH PUCH
Re: PROBLEM WITH PUCH
Hi,Tom! I did that once and even with sealed rear bearings,I had reversed a washer which then pressed on the bearing when tightened.Are you sure the brake return spring is pushing the arm back where it won't hold a little tension on the shoe against the drum?With drop-in ball bearings,you really have to watch that all are in there,and leave them a little loose rather than tight.BYE!
The sidewall of the tire is rubbing against one side of the rear swingarm.The swingarm is what the wheel attaches to.
Visit Sportsbay in the Shopping section of Yahoo for the largest selection of moped parts and accessories on the internet.
