I like grease, oil, gas, kerosene, but i don't like electricity.
Does anyone know if a brake light on a moped must be 6 volts?
Can you get them in dual filament bright/not bright @ 6 volts?
Will 12 volt #1267 work?
After pedalling and pedalling in 90% humidity (disconnecting everything along the way) i found out my spark plug is connected to a winky dink rear light. Why is it designed this way?
Also, don't mix car parts with moped parts (exhaust systems, carburators); i just got done replacing a dead brake light in my car, and somehow put it in the moped. Thanks.
