I have a 1986 spree. It starts up fine and idles fine, but when i increase the throttle, the engine starts to bog and it dies unless i ease up on the throttle. I cleaned the carb a half a dozen times, so i am almost possitive its not the carb. But since i bought this thing, i have always had problems with the automatic choke. For some reason when the choke was engaged the scooter wouldn't keep an idle. So i ended up just disableing the choke by disconecting one of the wires. This seemed to work... So after i cleaned the carb and put everything back to the way it was (with the disabled choke) it seemed to run alright. I let the thing sit over night and i started it up the next morning and took it to work, and it ran fine. When i started it up to take drive home, it was bogging. I ended up having to push the scooter home. so to wrap it all up, it starts great, it idles great, it just won't run or accelerate. please help.
spree problem
Re: spree problem
Bret
Sounds like a plugged exhaust to me. I had similar symptoms on my peugeot 103. Found pieces of carbon blocking the exit from the muffler. De-carbon the muffler is my suggestion.
Good luck.
Don
Re: spree problem
Bret,
Sounds more like a plugged main jet to me, have you installed a fuel filter?
Ron
Re: spree problem
I have not installed a fuel filter. How would i go about installing one.
Re: spree problem
Bret,
Pick up a small one at a motorcycle or lawn mower shop, cut the fuel line to the carb and splice it back together with the filter.
Ron
