RE: Garelli fuel ratio
ZippyMoped /
<HTML>According to the Clymer publications manual for 1976-78 Garelli the correct fuel ratio is 32:1 or 32 parts of regular gas and 1 part 2 stroke motor oil.
If the Garelli has an oil injector (white or clear plastic cylinder under the gas tank, running parallel to the tank). If you have an injector model, the ratio is 64:1 or 64 parts gas to 1 part ,2 stroke motor oil. The manual says to use Garelli Spectro oil or equivalent.
It also says to drain and replace the clutch oil every 1200 miles. The drain plug is under the engine near where the exhuast pipe joins the engine. Let drain for about 10 minutes and then replace plug and fill with SAE 30 weight NON DETERGENT oil. The fill plug is on the side of th clutch housing.
Good luck and Happy, safe, mopeding.
Zippy</HTML>
  Garelli fuel ratioTopic by: Joe Joe 10/17/99 08:24PM
  RE: Garelli fuel ratioRe: Will Outlaw Will Outlaw 10/19/99 03:21PM
  RE: Garelli fuel ratioRe: ZippyMoped ZippyMoped 10/25/99 03:06AM
  RE: Garelli fuel ratioRe: Pete Pete 01/01/00 04:11PM
