Re: Speedometer cable and Rear wheel
Brian /
You said it comes off the speedometer so just thread your cable out of the cabling between the front forks, make a diagram of how it's routed prior to taking it out so you'll know how it goes back. Remove the front wheel with the cable attached then take off the threaded spacer that goes between the forks and the drive unit. Now remove the drive/cable assembly and have a close look at it to determine what's holding it on. If it's working, don't break it trying to get the cable off, I'm assuming your just trying to get the front wheel off to fix a flat or put new tires on. You've accomplished that, now just put it back together and let sleeping dogs lay.
  Speedometer cable and Rear wheelTopic by: Nick Nick 07/18/01 09:43PM
  Re: Speedometer cable and Rear wheelRe: Brian Brian 07/18/01 10:24PM
  Re: Speedometer cable and Rear wheelRe: Nick Nick 07/19/01 12:04AM
  Re: Speedometer cable and Rear wheelRe: Brian Brian 07/19/01 10:45AM
  Re: Speedometer cable and Rear wheelRe: Ron Brown Ron Brown 07/19/01 11:52AM
  Re: Speedometer cable and Rear wheelRe: Nick Nick 07/20/01 09:38AM
  Re: Speedometer cable and Rear wheelRe: Ron Brown Ron Brown 07/20/01 01:08PM
  Re: Speedometer cable and Rear wheelRe: don-ohio don-ohio 07/20/01 01:20PM
