need more speed
<HTML>I have a 1988 yamaha Zoma it will co about 30-35 MPH. I would like to know a way to make it go a lot faster with out over halling the moped.
</HTML>
RE: need more speed
<HTML>You can change your air filter and put a stockings nylon.
If you do that you can win 10 mph.
Sorry but I am french !!!</HTML>
RE: need more speed
gloria hartness /
<HTML>I have the same problem with a new Tomos SR 50. It will only go to 53 mph or 60kmh. The dealer made me believe it would go faster. Now he says he can adjust the timing and possibly get 10 mph more. Does anyone have information on this?
Will the nylon act as an efficient air filter?
Thanks.</HTML>
RE: need more speed
<HTML>i have a honda pa0. i have the same problem. it is a 1979 and it goes about 15 mph top!! i need help!! thanks</HTML>
RE: need more speed
<HTML>does any one know how to de restrict a moped because i have has loads of people tell me different ways but the truth is they don't realy know.
Thanks</HTML>
RE: need more speed
matthew burke /
<HTML>
check the air filter and gear oil piston lube and chain to see if its slack and tighten it up make sure the petrol tap is on full not reserve </HTML>
