Re: oh yeah (addendum)
Terry Thompson /
I have a 16 x 2.75" sava tire and garelli wheel on the back of my puch and a 24" x 1.5"? bicycle rim/tire up front.
To do the wide rear wheel, you need to modify the rear swing arm because the inside gets very narrow where it meets the body (I imagine it's probably more difficult if you have a rigid frame).
It's disigned sort of like a V <-where the bottom of the v meets with the bike. You need to turn it into more of a U.
On mine, I removed the swing arm, cut and bent it so the wheel would clear and then re-welded it at the new angles.
I also chopped the rear fender to clear the tire movement since it's a soft-tail upward travel would cause the tire to scrape.
I don't see a problem with raking a moped. They are pretty much crap for low speed maneuverability as is and high speed wobble isn't an issue (unless you know how to get a moped to do 60mph). 35 deg. sounds good to me.
Problems. As a chopper, my puch is impossible to pedal any good distance.
-Firespitter
  my dream projectTopic by: Josh S Josh S 12/31/03 12:30AM
  oh yeah (addendum)Re: Josh S Josh S 12/31/03 12:32AM
  Re: oh yeah (addendum)Re: Tyler Jacobson Tyler Jacobson 12/31/03 12:45AM
  i dunno but i think 4 inchesRe: Josh S Josh S 12/31/03 12:47AM
  Re: oh yeah (addendum)Re: Terry Thompson Terry Thompson 12/31/03 11:03AM
  Re: oh yeah (addendum)Re: Josh S Josh S 12/31/03 04:34PM
  headliteRe: Josh S Josh S 12/31/03 12:45AM
  Re: headlite (from an old caddy!! no!)Re: W B W B 01/02/04 09:06PM
  ah well just want it for the looksRe: Josh S Josh S 01/02/04 09:56PM
  Re: ah well just want it for the looksRe: Don Pflueger Don Pflueger 01/02/04 10:08PM
  pix?Re: Josh S Josh S 01/02/04 10:41PM
  Re: my dream projectRe: Chris Rice Chris Rice 12/31/03 11:08AM
  no they aren'tRe: Josh S Josh S 12/31/03 04:35PM
  Re: no they aren'tRe: Matthew Coles Matthew Coles 12/31/03 05:10PM
  teeth suggestions?Re: Josh S Josh S 12/31/03 05:22PM
  I have never seen......Re: Don Ohio Don Ohio 01/01/04 12:46AM
  hmmRe: Josh S Josh S 01/02/04 11:20PM
  although going with 19s would be amusing tooRe: Josh S Josh S 01/02/04 11:22PM
  Re: teeth suggestions?Re: Matthew Coles Matthew Coles 12/31/03 06:38PM
  Re: teeth suggestions?Re: Matthew Coles Matthew Coles 12/31/03 07:23PM
  paintRe: Josh S Josh S 12/31/03 10:57PM
  Re: my dream projectRe: Luke Evans Luke Evans 12/31/03 11:44PM
  now MY dream projectRe: Robert Blackmon Robert Blackmon 01/01/04 01:57AM
  from another forum i got thisRe: Josh S Josh S 01/02/04 04:39PM
  Re: from another forum i got thisRe: Robert Blackmon Robert Blackmon 01/02/04 10:11PM
  Re: from another forum i got thisRe: Don Pflueger Don Pflueger 01/02/04 10:21PM
  hehehe a neg and a neg equal a positiveRe: Josh S Josh S 01/02/04 10:35PM
  Re: my dream projectRe: Timmy Southpark Timmy Southpark 01/01/04 08:31PM
  that orRe: Josh S Josh S 01/02/04 04:40PM
  Re: my dream projectRe: Matthew Coles Matthew Coles 01/01/04 08:41PM
  Re: my dream projectRe: Andrew Ragone Andrew Ragone 01/01/04 08:47PM
  Re: my dream projectRe: Terry Thompson Terry Thompson 01/01/04 09:38PM
  lolololRe: Josh S Josh S 01/02/04 04:44PM
  i've been told that...Re: Josh S Josh S 01/02/04 04:42PM
  Re: i've been told that...Re: Terry Thompson Terry Thompson 01/02/04 05:19PM
  hmmRe: Josh S Josh S 01/02/04 05:24PM
  Re: hmmRe: Matthew Coles Matthew Coles 01/02/04 05:31PM
  yeah prollyRe: Josh S Josh S 01/02/04 05:34PM
  Re: yeah prollyRe: Matthew Coles Matthew Coles 01/02/04 05:41PM
  hey that IS neatRe: Josh S Josh S 01/02/04 05:45PM
  Re: hey that IS neatRe: Kenneth Bailey Kenneth Bailey 01/02/04 06:07PM
  an interesting concept...Re: Josh S Josh S 01/02/04 06:13PM
  Re: hey that IS neatRe: Terry Thompson Terry Thompson 01/02/04 07:07PM
  yeah i seen the triumph onesRe: Josh S Josh S 01/02/04 10:00PM
  Re: hey that IS neatRe: Matthew Coles Matthew Coles 01/02/04 07:46PM
  Re: hey that IS neatRe: Andrew Ragone Andrew Ragone 01/02/04 08:14PM
  Re: hey that IS neatRe: Matthew Coles Matthew Coles 01/02/04 08:19PM
  Re: hey that IS neat (gel-cells!)Re: W B W B 01/02/04 08:49PM
  dream project (GPS &amp; 6 to 12v convert)Re: W B W B 01/02/04 08:56PM
  no not yetRe: Josh S Josh S 01/02/04 10:04PM
  my dream project (front disc brakes)Re: W B W B 01/02/04 09:01PM
  well...Re: Josh S Josh S 01/02/04 10:08PM
  Re: my dream projectRe: William Laing William Laing 01/02/04 11:34PM
  they make bings that big bro?Re: Josh S Josh S 01/02/04 11:35PM
  How's this for insane?Re: Terry Thompson Terry Thompson 01/02/04 11:46PM
  hrmRe: Josh S Josh S 01/02/04 11:59PM
  Re: hrmRe: Terry Thompson Terry Thompson 01/03/04 09:23AM
  then my next question isRe: Josh S Josh S 01/03/04 04:10PM
  Re: then my next question isRe: Terry Thompson Terry Thompson 01/03/04 07:19PM
  DISK BRAKESRe: Tyler Jacobson Tyler Jacobson 01/03/04 01:01AM
  disc break stuffRe: Josh S Josh S 01/03/04 03:04AM
  answer to the disc break issueRe: Josh S Josh S 01/03/04 03:06AM
  suspension?Re: Josh S Josh S 01/03/04 05:18PM
  Re: suspension?Re: Matthew Coles Matthew Coles 01/03/04 06:16PM
  uh-ohRe: Nick K Nick K 01/04/04 07:07PM
  thanks :)Re: Josh S Josh S 01/05/04 05:53PM
  PROJECT UPDATERe: Josh S Josh S 01/05/04 05:54PM
  Re: PROJECT UPDATERe: Nick K Nick K 01/05/04 07:55PM
