Help with my POS
Carl Wallace /
Hey,
I got a 1994 Jawa Sport Top tank and i need some help. It run fine, idles fine, but when i give it gas, the engine races but i dont go anyware. It takes forever to get up to speed and i have to run beside it to get the thing up a hill.
HELP!!!
Carl
Re: Help with my POS
Hi,Carl! Could you have burned out your clutches or could the fluid be really low(if it's a wet type clutch)?
Jamie Leonard /
It might be the dry type clutch (flywheel) in which case you will need to clean the thing first (there are some notes on here if you do a search, but basically you need to take it apart, clean everything with something that'll get any grease out (if it is a dry type clutch) and then possibly lightly sand with a very very very very fine grade sandpaper
Reeperette /
Definately a slipping clutch or belt problem.
Check, recondition...possibly replace clutch.
Check belt for slipping, apply belt dressing,maybe replace belt.
Could you have the wrong belt on there, possibly ? the correct one has rubber "teeth" on it, as I recall.
-Ree
