speed spocket
Do any of you know what a speed spocket is because some ppl say it makes your ped go faster.
Re: speed spocket
XBrandon EdgeX /
A speed sprocket is a different sprocket with more or less teeth on it to change performance. a bigger sprocket on the engine or a smaller sprocket on the wheel will give you more top speed, but takes away acceleration. a smaller sprocket on the engine or a bigger sprocket on the back gives you more low end torque and acceleration, but takes away from top speed.
Re: speed spocket
Yes, its just a sprocket on the rear hub that is smaller ( less teeth ) than the one that's on there now. You can also use a larger ( more teeth ) countershaft sprocket, that's the sprocket that is attatched to the engine or belt pulley. For mopeds it's usually easier to put a smaller rear sprocket on and shorten the chain.
Re: speed spocket
Wayne Broderick /
I'm not concerned w/top end-- I'm going to go for pulling power-- When I get the piston kit, I plan on using both front and rear power sprockets.
Ree-- Do you know, would this give a ton of low end or what? I'm pretty close to having enough loot to buy it.
(Targa, 2000 model)
Thanks
Re: speed spocket
Reeperette /
Yeah, you'd lose tons of top end, but you'd prolly be able to spin em on start.
You gotta Bi-Turbo on that thing ? cause I would do both...sprocket mods and Bi-Turbo, you'd have mega jumpoff power.
Don't forget the kickstand...mind.
-Ree
