Is there a govenor on a 1982 honda50 urban express
im wanting to know this because my moped goes 20 if that and its suposto go 35.
Re: Is there a govenor on a 1982 honda50 urban exp
Its been my experience that it has more to do with the adjustments, idle speed, mixture, and such on the carb. Sorry with out seeing it I cant really help much more than that
heres the moped
Hey Jake, while your express was never meant to be a speed demon, you may want to post your question on http//expresslymopeds.50megs.com by the way thats a very clean ped...
No there is no Gov. Read Fred's Book. It is most likely plugged exhaust, or you may need change the main jet, I had to go to an 80.
Tom
hey jake,
i have the exact same moped as you and i have the same problem, when i first baught the ped it did about 28-29 and know it hardly does 20mph, just wondering if any one knew any thing else thet could be the problem thanks,
will
ok i just cleaned the exhaust ond the carb both where clean,,, what else ?????
Hey Jake and Will ! Do what MADDOG said and go to the forum on that web site! I just saw where a Honda NC 50,I think, HAS a governor and the post on the forum tells what to look for.But I still don't know if you have a governor or not,for sure.BYE!
mike hartel /
it does have a governor take off the cover marked in the pic and and the FRONT PULLY and the plate bolted on the pully take it off.
and it still runs like crap
mike,
are you positive? I dont really want to mess it (my moped) up, ive had that cover before and some gears and its tuff to get it back together. Well i guess ill try it any way THanks
will g
Ron Brown /
Will,
When was "then" as in it used to... and howh many miles ago and have you cleaned the exhaust port?
Ron
Jake,
I took the kick start off my moped and i need to know how to line the gears up properly.
Thanks
will g
Install the kick pedal by aligning its punch mark with the punch mark of the spindle.
Tighten the pedal pinch bolt
Tighten the crankcase cover bolts while pushing and holding the starter pedal down 15 degrees or more.
