Re: gas gauge?
Brian /
Could be the mag wheels, take one off and compare it with a spoked wheel. I own a Puch Cobra with spoked wheels and it's pretty light, so was the Maxi II I used to own but I never weighed it. If you want better gas mileage you can take your carbs main needle out and move the circlip up a notch. Up to lean, down to richen. Put a new plug in and check it after riding to make sure your not running too lean. You could have a fuel leak, dragging brake, bad wheel bearing, worn out and dry chain, or your engine could be just plain worn out.
  gas gauge?Topic by: Mike Mike 07/11/01 01:02AM
  Re: gas gauge?Re: Brian Brian 07/11/01 01:22AM
  Re: gas gauge?Re: Mike Mike 07/11/01 01:35AM
  Re: gas gauge?Re: Reeperette Reeperette 07/11/01 07:54AM
  i know what you mean!Re: Mike Mike 07/11/01 01:27PM
  Stuff the mileage !Re: Reeperette Reeperette 07/12/01 06:13AM
  Re: gas gauge?Re: Brian Brian 07/11/01 09:39AM
  WeightRe: Chris Robertson Chris Robertson 07/18/01 01:02PM
  Re: gas gauge?Re: Rich King Rich King 07/11/01 01:51PM
  Try it.Re: gimmyjimmy gimmyjimmy 07/11/01 11:03PM
  Re: Try it.Re: Reeperette Reeperette 07/12/01 06:22AM
  Re: Try it.Re: Rich King Rich King 07/16/01 04:29PM
  Re: Try it.Re: gimmyjimmy gimmyjimmy 07/16/01 10:52PM
