Ron Brown wrote:
> Bryan,
> Your coil is most likely ok. Different meters give different
> readings and yours sounds close enough.
I checked again i nthe evening, and in the darker light, I could see a good spark. But it still doesn't fire...
> If you have points, make sure they are opening and closing
> and making good contact.
> If not, check all the connections to the electroninic
> ignition module and ignition switch. Make sure the plug cap
> is good too. Especially look for something you may have
> disturbed while changing the jet.
There are no wires around the carb. and everything checks out... I pulled the gas line, and it spits out gas, just like it should...
it just refuses to fire... could the plug be somehow be getting Un grounded when in the head?
