Re: Yamaha QT 50 oddity
Ron Brown /
Bryan,
Without being picky here, this is a classic symptom of running too rich. If you are too lean, you should be able to speed up by operating the choke slightly/briefly.
>> Turning off the gas at full speed caused the power to return
>> just before it died.
>Not power to return, just stopped loosing power long enough for the speed to build up...
You have to shake the float to check for gas inside it. The chances of having a big enough leak to sink it or blow bubbles are slim.
>> Maybe there is fuel in the float, affecting your fuel level.
> THe last time i had the carb off, I poured some gas in a big bowl, and held the
> float under the gas for a few minutes... didn't seem to gather any gas inside it... > and I didn't see bubbles of air escaping.
What did the plug look like and did you check it after a high speed chop or after idling a while?
> I was thinking it might be running too lean, actually, after seeing the spark plug > again.
By the way, screwing around with the oil injection could cause severe engine damage, besides confusing the symptoms. You should set it exactly as the book says.
Ron
  Yamaha QT 50 oddityTopic by: bryan bryan 07/10/01 12:52AM
  Re: Yamaha QT 50 oddityRe: MR MR 07/10/01 02:29AM
  Re: Yamaha QT 50 oddityRe: Carmen Carmen 07/11/01 12:14PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/10/01 04:01PM
  Re: Yamaha QT 50 oddityRe: don-ohio don-ohio 07/12/01 10:42PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 12:56AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 01:04AM
  Re: Yamaha QT 50 oddityRe: don-ohio don-ohio 07/16/01 02:08AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 03:01PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/16/01 03:20PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/18/01 01:41AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/18/01 12:21PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/18/01 02:37PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 01:22AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 11:57AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 02:02PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 03:02PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 04:08PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 05:41PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 06:39PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 07:24PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/20/01 11:13PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/21/01 11:35AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/21/01 03:43PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/22/01 06:30PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/22/01 08:58PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/23/01 01:06PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/23/01 10:47PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/24/01 10:59AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/24/01 11:57AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/24/01 01:22PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/24/01 09:06PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/25/01 10:18AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/26/01 04:30PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/26/01 06:01PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/27/01 12:24AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/27/01 11:38AM
  Re: Yamaha QT 50 oddityRe: Shawna Guy Shawna Guy 08/26/02 02:38AM
  Re: Yamaha QT 50 oddityRe: Bryan Bryan 08/26/02 03:26AM
  Re: Yamaha QT 50 oddityRe: Caton9 Caton9 10/21/02 06:02PM
  Re: Yamaha QT 50 oddity parts!Re: Bryan Bryan 10/21/02 06:17PM
  Re: Yamaha QT 50 oddityRe: Wayne Wayne 08/26/02 09:10AM
  Re: Yamaha QT 50 oddityRe: brynab brynab 07/21/01 07:26PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 12:24AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/30/01 12:18PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 01:46PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/30/01 02:08PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 11:01PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/31/01 11:46AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/10/01 11:47PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/10/01 11:51PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/11/01 12:34PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/13/01 08:54PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/14/01 12:19PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/14/01 03:55PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/15/01 01:03PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 01:17AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/16/01 12:45PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 02:00PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 04:42PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/16/01 08:38PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/17/01 02:02AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/17/01 12:51PM
  Re: Yamaha QT 50 oddityRe: Brian Brian 08/17/01 03:27PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/17/01 02:03AM
  Re: Yamaha QT 50 oddityRe: Roy Markee Roy Markee 11/12/01 02:03AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 11/12/01 12:43PM
  Re: Yamaha QT 50 oddityRe: k rude k rude 10/19/02 06:02PM
  Re: Yamaha QT 50 oddityRe: Joe Hunt Joe Hunt 10/21/02 12:30AM
