Re: Yamaha QT 50 oddity
bryanb /
PROGRESS!!! read on...
> Assuming the float is hollow, did you actually shake it to
> make sure there was no gas in it? This would still float but
> raise the fuel level in the carb.
I don't remember any. my friend Allen was pretty experienced withthe float bowl, as he just went through a incident on his Honda Accord, where the floats were bad... so it was fresh in his mind to check it...
> I am not sure and I would expect it to screw up the idle, but
> if your reed valve leaks, some of the mixture gets blown back
> into the carb where it picks up more fuel.
That makes sense. I read something somewhere (probably this thread) where a guy was having the same _orginal_ problem after he hopped up the bike, and it would blowback into the carb, and even get the air filter wet, and suck it into the carb...
> If you have been playing with the throttle cable, you may
> have changed the oil pump adjustment. It is worth checking
> but unlikely to cause the problem.
I found a few adjustments in the shop manual I have. Only one of them I was able to understand/do without special tools. It just entailed adjusting the slack in the oil throttle cable. Apparently there is a little screw thats supposed to line up with a make on the oil pump, and it wasn't... So lined it up, and it runs much better now...
> I don't remember us ever discussing the choke, what kind do
> you have and are you sure it is completely off?
I would say so, yeah... the choke lever is pulled all the way to off, and the choke cable seems all the way down. (moving it up, kills the engine)
I also took the exhaust off and tried cleaning the exhaust port. it wasn't plugged, but the whole thing, and the pipe is caked on the inside walls. I scraped what I could/reach....
So now im back to the orginal problem of stalling/flooding/cutting out/ drop in power (whatever you want to call it) at about 24mph.... Getting over 20 now, but still not getting what I used to....
  Yamaha QT 50 oddityTopic by: bryan bryan 07/10/01 12:52AM
  Re: Yamaha QT 50 oddityRe: MR MR 07/10/01 02:29AM
  Re: Yamaha QT 50 oddityRe: Carmen Carmen 07/11/01 12:14PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/10/01 04:01PM
  Re: Yamaha QT 50 oddityRe: don-ohio don-ohio 07/12/01 10:42PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 12:56AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 01:04AM
  Re: Yamaha QT 50 oddityRe: don-ohio don-ohio 07/16/01 02:08AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 03:01PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/16/01 03:20PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/18/01 01:41AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/18/01 12:21PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/18/01 02:37PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 01:22AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 11:57AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 02:02PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 03:02PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 04:08PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 05:41PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 06:39PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 07:24PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/20/01 11:13PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/21/01 11:35AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/21/01 03:43PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/22/01 06:30PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/22/01 08:58PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/23/01 01:06PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/23/01 10:47PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/24/01 10:59AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/24/01 11:57AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/24/01 01:22PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/24/01 09:06PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/25/01 10:18AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/26/01 04:30PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/26/01 06:01PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/27/01 12:24AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/27/01 11:38AM
  Re: Yamaha QT 50 oddityRe: Shawna Guy Shawna Guy 08/26/02 02:38AM
  Re: Yamaha QT 50 oddityRe: Bryan Bryan 08/26/02 03:26AM
  Re: Yamaha QT 50 oddityRe: Caton9 Caton9 10/21/02 06:02PM
  Re: Yamaha QT 50 oddity parts!Re: Bryan Bryan 10/21/02 06:17PM
  Re: Yamaha QT 50 oddityRe: Wayne Wayne 08/26/02 09:10AM
  Re: Yamaha QT 50 oddityRe: brynab brynab 07/21/01 07:26PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 12:24AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/30/01 12:18PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 01:46PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/30/01 02:08PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 11:01PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/31/01 11:46AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/10/01 11:47PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/10/01 11:51PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/11/01 12:34PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/13/01 08:54PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/14/01 12:19PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/14/01 03:55PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/15/01 01:03PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 01:17AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/16/01 12:45PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 02:00PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 04:42PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/16/01 08:38PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/17/01 02:02AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/17/01 12:51PM
  Re: Yamaha QT 50 oddityRe: Brian Brian 08/17/01 03:27PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/17/01 02:03AM
  Re: Yamaha QT 50 oddityRe: Roy Markee Roy Markee 11/12/01 02:03AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 11/12/01 12:43PM
  Re: Yamaha QT 50 oddityRe: k rude k rude 10/19/02 06:02PM
  Re: Yamaha QT 50 oddityRe: Joe Hunt Joe Hunt 10/21/02 12:30AM
