Re: Yamaha QT 50 oddity
Ron Brown /
Bryan,
Its only an engine : )
Good on the missing screw, I am sure it is a fixed jet in your carb.
Assuming the float is hollow, did you actually shake it to make sure there was no gas in it? This would still float but raise the fuel level in the carb.
I am not sure and I would expect it to screw up the idle, but if your reed valve leaks, some of the mixture gets blown back into the carb where it picks up more fuel.
If you have been playing with the throttle cable, you may have changed the oil pump adjustment. It is worth checking but unlikely to cause the problem.
I don't remember us ever discussing the choke, what kind do you have and are you sure it is completely off?
Ron
  Yamaha QT 50 oddityTopic by: bryan bryan 07/10/01 12:52AM
  Re: Yamaha QT 50 oddityRe: MR MR 07/10/01 02:29AM
  Re: Yamaha QT 50 oddityRe: Carmen Carmen 07/11/01 12:14PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/10/01 04:01PM
  Re: Yamaha QT 50 oddityRe: don-ohio don-ohio 07/12/01 10:42PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 12:56AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 01:04AM
  Re: Yamaha QT 50 oddityRe: don-ohio don-ohio 07/16/01 02:08AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 03:01PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/16/01 03:20PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/18/01 01:41AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/18/01 12:21PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/18/01 02:37PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 01:22AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 11:57AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 02:02PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 03:02PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 04:08PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 05:41PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 06:39PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 07:24PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/20/01 11:13PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/21/01 11:35AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/21/01 03:43PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/22/01 06:30PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/22/01 08:58PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/23/01 01:06PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/23/01 10:47PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/24/01 10:59AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/24/01 11:57AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/24/01 01:22PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/24/01 09:06PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/25/01 10:18AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/26/01 04:30PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/26/01 06:01PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/27/01 12:24AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/27/01 11:38AM
  Re: Yamaha QT 50 oddityRe: Shawna Guy Shawna Guy 08/26/02 02:38AM
  Re: Yamaha QT 50 oddityRe: Bryan Bryan 08/26/02 03:26AM
  Re: Yamaha QT 50 oddityRe: Caton9 Caton9 10/21/02 06:02PM
  Re: Yamaha QT 50 oddity parts!Re: Bryan Bryan 10/21/02 06:17PM
  Re: Yamaha QT 50 oddityRe: Wayne Wayne 08/26/02 09:10AM
  Re: Yamaha QT 50 oddityRe: brynab brynab 07/21/01 07:26PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 12:24AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/30/01 12:18PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 01:46PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/30/01 02:08PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 11:01PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/31/01 11:46AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/10/01 11:47PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/10/01 11:51PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/11/01 12:34PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/13/01 08:54PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/14/01 12:19PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/14/01 03:55PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/15/01 01:03PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 01:17AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/16/01 12:45PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 02:00PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 04:42PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/16/01 08:38PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/17/01 02:02AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/17/01 12:51PM
  Re: Yamaha QT 50 oddityRe: Brian Brian 08/17/01 03:27PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/17/01 02:03AM
  Re: Yamaha QT 50 oddityRe: Roy Markee Roy Markee 11/12/01 02:03AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 11/12/01 12:43PM
  Re: Yamaha QT 50 oddityRe: k rude k rude 10/19/02 06:02PM
  Re: Yamaha QT 50 oddityRe: Joe Hunt Joe Hunt 10/21/02 12:30AM
