Re: Yamaha QT 50 oddity
bryanb /
thanks for you persisent interest!!
>Ron Brown wrote:
> Bryan
> I just went back and read most of this thread.
> Get focused and complete, or respond to one thing at a time
> before we all go nuts.
> This thread started with your ped running too rich and
> displaying all the classic symptoms. The following are some
> questions asked by you, me or someone else which do not seem
> to have good answers yet, at least in the thread.
> Are you sure your needle valve and float are good and there
> is no gas in the float causing your fuel level to be too high?
THe float seemed fine the second time I took the carb apart at a friends place with an air compressor... it floated in the gas tank of his Harley Davidson. the needle valve seems fine.
> Did you determine that the screw in the side of the carb was
> not supposed to be there?
THis one is tough to answer. there are no threads in the hole there... and there appears to be a (factory)plug inside that hole. the manual I have is for a QT 50 F. Im not sure what suffix mine has.... its a 1980... the namual also doesn't show the idle mixture screw, just the idle speed screw....
> Have you checked the exhaust port for carbon build up?
thats on today's agenda, along with checking the oil pump in some way, shape or form...
> Do you have a reed valve and if so, is it ok?
I guess I could look at that too... My 'Harley', Allen didn't think it would be of any benefit, but your right, I haven't looked at it... looks like bitch to get at though...
> Ther may be more, but for running rich, these will do for now.
> Ron
  Yamaha QT 50 oddityTopic by: bryan bryan 07/10/01 12:52AM
  Re: Yamaha QT 50 oddityRe: MR MR 07/10/01 02:29AM
  Re: Yamaha QT 50 oddityRe: Carmen Carmen 07/11/01 12:14PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/10/01 04:01PM
  Re: Yamaha QT 50 oddityRe: don-ohio don-ohio 07/12/01 10:42PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 12:56AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 01:04AM
  Re: Yamaha QT 50 oddityRe: don-ohio don-ohio 07/16/01 02:08AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/16/01 03:01PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/16/01 03:20PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/18/01 01:41AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/18/01 12:21PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/18/01 02:37PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 01:22AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 11:57AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 02:02PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 03:02PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 04:08PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 05:41PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/19/01 06:39PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/19/01 07:24PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/20/01 11:13PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/21/01 11:35AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/21/01 03:43PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/22/01 06:30PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/22/01 08:58PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/23/01 01:06PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/23/01 10:47PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/24/01 10:59AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/24/01 11:57AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/24/01 01:22PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/24/01 09:06PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/25/01 10:18AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/26/01 04:30PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/26/01 06:01PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/27/01 12:24AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/27/01 11:38AM
  Re: Yamaha QT 50 oddityRe: Shawna Guy Shawna Guy 08/26/02 02:38AM
  Re: Yamaha QT 50 oddityRe: Bryan Bryan 08/26/02 03:26AM
  Re: Yamaha QT 50 oddityRe: Caton9 Caton9 10/21/02 06:02PM
  Re: Yamaha QT 50 oddity parts!Re: Bryan Bryan 10/21/02 06:17PM
  Re: Yamaha QT 50 oddityRe: Wayne Wayne 08/26/02 09:10AM
  Re: Yamaha QT 50 oddityRe: brynab brynab 07/21/01 07:26PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 12:24AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/30/01 12:18PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 01:46PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/30/01 02:08PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 07/30/01 11:01PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 07/31/01 11:46AM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/10/01 11:47PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/10/01 11:51PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/11/01 12:34PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/13/01 08:54PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/14/01 12:19PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/14/01 03:55PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/15/01 01:03PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 01:17AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/16/01 12:45PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 02:00PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/16/01 04:42PM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/16/01 08:38PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/17/01 02:02AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 08/17/01 12:51PM
  Re: Yamaha QT 50 oddityRe: Brian Brian 08/17/01 03:27PM
  Re: Yamaha QT 50 oddityRe: bryanb bryanb 08/17/01 02:03AM
  Re: Yamaha QT 50 oddityRe: Roy Markee Roy Markee 11/12/01 02:03AM
  Re: Yamaha QT 50 oddityRe: Ron Brown Ron Brown 11/12/01 12:43PM
  Re: Yamaha QT 50 oddityRe: k rude k rude 10/19/02 06:02PM
  Re: Yamaha QT 50 oddityRe: Joe Hunt Joe Hunt 10/21/02 12:30AM
