honda express short
Matty Heard /
Hi,
I have a 1980 honda nc50 express. I recently started it, and the low beam wouldn't work. Then I switched to the high beam, and it blew out right away. I got a new battery and headlight ( the old battery was completely dead, and I missed not having blinkers) and hooked everything up. The new headlight blew out right away. Whats going on here? What should I check? Any help is appreciated.
Matty
Re: honda express short
Sound like your voltage regulators shot.
Could also be that the rectifier isn't grounded properly. Check the Expressly Mopeds forum for info on Honda Express.
Jim C.
Dude,
I got screwed like that because I put a fuse in the line near the battery that was not long enough to make contact at both ends all the time. I blew the headlight several times before I figured it out. Make sure your fuse is the correct length!
Andrew
