Re: rusty gas tank
XBrandon EdgeX /
I sandblasted the inside of my tank. It worked pretty good from what I could see, and my fuel filter has been clean ever since. The only downside is getting the sand out. I had to run compressed air through it for about an hour! Then, I rinsed it out with gas a few times. I tried acid, but the stuff I got was too weak. I used "Lime Away" and it didn't do anything. I couldn't find any Phosphoric acid and I heard that muriatic acid requires a coating after using because it's so corrosive and will start rusting right away if you don't paint it or keep the tank full of gas all the time.
If you sandblast the tank, you should use a fuel filter (well, you should use a fuel filter no matter what).
  rusty gas tankTopic by: cookster cookster 07/05/01 02:01PM
  Re: rusty gas tankRe: don-ohio don-ohio 07/05/01 02:09PM
  Re: rusty gas tankRe: cookster cookster 07/05/01 02:24PM
  Re: rusty gas tankRe: don-ohio don-ohio 07/05/01 03:25PM
  Re: rusty gas tankRe: XBrandon EdgeX XBrandon EdgeX 07/05/01 03:40PM
  Re: rusty gas tankRe: Chris Robertson Chris Robertson 07/05/01 04:46PM
  Re: rusty gas tankRe: Ron Brown Ron Brown 07/06/01 10:32AM
  Re: rusty gas tankRe: mp mp 07/13/01 02:47AM
