Re: 1979 sachs 505
don-ohio /
Hi,Roger! While you're waiting for your shop manual,which Jamie is right,you need one, why don't you pull the clutch housing cover and take a look.I've never had it happen,but I,ve heard where the tapered mounting hole may not be seated tight on the crankshaft and the clutch assembly may just be spinning on the crankshaft.OR ,you may see another problem while you're in there.Watch out! There may be an opposite turning nut on it(left-hand threads),so look at the threads before you put force on it.Keep us posted,O.K.?
  1979 sachs 505Topic by: roger roger 07/04/01 03:05PM
  Re: 1979 sachs 505Re: don-ohio don-ohio 07/04/01 03:14PM
  Re: 1979 sachs 505Re: roger roger 07/04/01 08:40PM
  Re: 1979 sachs 505Re: Jamie Leonard Jamie Leonard 07/05/01 01:05AM
  Re: 1979 sachs 505Re: don-ohio don-ohio 07/05/01 09:25AM
  Re: 1979 sachs 505Re: roger roger 07/05/01 08:07PM
  Re: 1979 sachs 505Re: don-ohio don-ohio 07/12/01 08:55PM
  Re: 1979 sachs 505Re: Mike Mike 07/05/01 10:01AM
