carb adjustments for '82 honda
will gettler /
I have a 1982 honda urban express moped, it has an automatic choke on the carb. is 2 adjustment screws whitch one is air and which one is fuel and how many turns in or out shold each screw be? 2nd problem is once i start the moped and get going then let off of the throttle it wants to die. then is really hard to start back up again.
thanks
will gettler
Re: carb adjustments for '82 honda
Hi,Will! Are you sure one of those screws,probably the uppermost,isn't an idle adjustment screw? If it is,maybe all you need is to turn it in a little to get the bike to idle,right? BYE!
The top screw is the idle speed, lower one is the idle mixture, 2 turns out aprox.
At the bottom is a drain valve. Sounds like carb could use a good cleaning.
I have found to start hot it helps to open the throttel a little, very little.
Tom
bump
does this sound about right? (edited)
fifteen years old
moped man is a
mind reader because
this week
i was going to refresh
my memory on these
screws
thank you mnm
Dustin Schings /
Hahaha, wow, this is an old thread! You can tell too because back then people couldn't just GOOGLE something this simple like you can today.
