RE: Breakdown:(
leo /
ped
hope you are mixing gas and oil at 1 ounce
or 30cc to 1/3 gallon of hi octane gas.
that said, when you try to start it and it
doesn*t start is the spark plug getting wet
from the gas/oil mixture from the carb reaching the plug, if not maybe a fuel
problem.
take the plug out of the motor and put the plug in the ignition wire and lay the plug
across the cylinder head and kick it over--
you should be able to see a spark flash
across the spark plug electrodes. if so
then maybe not a ignition problem.
as i learned in class it has to be one of
three things 1. ignition
2. carburation
3. compression
put thumb in spark hole and kick over--if
compression your thumb will be pushed out of
plug hole. sounds like carburation to me
  Breakdown:(Topic by: Outlaw Outlaw 09/10/99 01:06AM
  RE: Breakdown:(Re: leo leo 09/22/99 02:48PM
