Re: An Exedrin moment
Reeperette /
Umm...Nick ? put down the chainsaw......heh....try that #66 Jet - with a 15mm Carb and a #82, it's probably gargling on the fuel instead of firing it.
Spin the plug out and use a hair dryer on it, if it's wet when you pull it.
If you get fire with the #66, check the mix asap...and make sure that's not too lean, given that you have 50:1 in the tanks.
Always try lean first...it's easier to fire, and then richen up to a good point, rather than the reverse...it saves a lotta headaches of this sort.
-Ree
  An Exedrin momentTopic by: Nick Nick 07/02/01 07:45AM
  Re: An Exedrin momentRe: gimmyjimmy gimmyjimmy 07/02/01 08:01AM
  Re: An Exedrin momentRe: don-ohio don-ohio 07/02/01 10:37AM
  Re: An Exedrin momentRe: Reeperette Reeperette 07/02/01 04:19PM
  Re: An Exedrin momentRe: Nick Nick 07/02/01 06:14PM
  Re: An Exedrin momentRe: stonneredog stonneredog 07/04/01 02:58AM
  Re: An Exedrin momentRe: Nick Nick 07/04/01 09:33AM
  Re: An Exedrin momentRe: don-ohio don-ohio 07/04/01 10:07AM
  Re: An Exedrin momentRe: Nick Nick 07/04/01 12:23PM
  Re: An Exedrin momentRe: don-ohio don-ohio 07/04/01 01:00PM
