RE: Bulbs keep blowing
bill /
the tomos has a two coil system because (or so tomos said) for safety reasons.
as you already figured out if you hit the brake the flow of electricity ends at the burnt out bulb and the moped dies.
two suggestions:
1 make sure the wire is grounded and placed in the wiring strip properly
2 if that doesn't work buy a bulb at a mejier or an auto shop that is made to handle 12 volts. It won't be as brite but it won't burn out.
write back and tell me if it works
  Bulbs keep blowingTopic by: Jerry Lansing Jerry Lansing 09/03/99 01:15PM
  RE: Bulbs keep blowingRe: simon simon 09/11/99 03:37PM
  RE: Bulbs keep blowingRe: bill bill 09/16/99 07:22PM
  RE: Bulbs keep blowingRe: Pete Pete 01/01/00 04:15PM
