Re: Stripped Drain Plug
gimmyjimmy /
self tapping plugs only cut new threads the first time you use them, after that, they install like a normal plug.
either way, you'll need new threads in the hole, and add a little teflon tape to help seal, and don't over tighten.
  Stripped Drain PlugTopic by: Ataristyle Ataristyle 06/27/01 02:05PM
  Re: Stripped Drain PlugRe: Ron Brown Ron Brown 06/27/01 06:35PM
  Re: Stripped Drain PlugRe: Reeperette Reeperette 06/27/01 11:55PM
  Re: Stripped Drain PlugRe: Ataristyle Ataristyle 06/28/01 12:37AM
  Re: Stripped Drain PlugRe: don-ohio don-ohio 06/28/01 01:00AM
  Re: Stripped Drain PlugRe: gimmyjimmy gimmyjimmy 06/28/01 08:59AM
  Re: Stripped Drain PlugRe: Doug D. Doug D. 06/28/01 10:19AM
  Re: Stripped Drain PlugRe: gimmyjimmy gimmyjimmy 06/28/01 10:47AM
  Re: Stripped Drain PlugRe: Ataristyle Ataristyle 06/28/01 01:39PM
