Re: Stripped Drain Plug
Doug D. /
On a self taping plug you will push metal bits up into the unit every time it`s installed, and on the soft metal you will only get so many uses. I bought a cheap tap set, with both sae+metric, if metric you can go to next size using standard without any drilling, and same for standard. Hate it when threads screw up! doug D
  Stripped Drain PlugTopic by: Ataristyle Ataristyle 06/27/01 02:05PM
  Re: Stripped Drain PlugRe: Ron Brown Ron Brown 06/27/01 06:35PM
  Re: Stripped Drain PlugRe: Reeperette Reeperette 06/27/01 11:55PM
  Re: Stripped Drain PlugRe: Ataristyle Ataristyle 06/28/01 12:37AM
  Re: Stripped Drain PlugRe: don-ohio don-ohio 06/28/01 01:00AM
  Re: Stripped Drain PlugRe: gimmyjimmy gimmyjimmy 06/28/01 08:59AM
  Re: Stripped Drain PlugRe: Doug D. Doug D. 06/28/01 10:19AM
  Re: Stripped Drain PlugRe: gimmyjimmy gimmyjimmy 06/28/01 10:47AM
  Re: Stripped Drain PlugRe: Ataristyle Ataristyle 06/28/01 01:39PM
