bypass the harness
Fred /
To get it to run just run one wire coming from the points straight to the input wire on the coil.
.. Just bypass the entire rest of the electric system to get it to run.
Then you can figure out what to do to "rewire" it if you want to.
If you go straight from the points to the coil you won't have an on/off switch... but you can work that in later.
  Honda PA50-II electricsTopic by: Tom Waddington Tom Waddington 06/26/01 04:15PM
  bypass the harnessRe: Fred Fred 06/26/01 05:54PM
  Re: bypass the harnessRe: Ron Brown Ron Brown 06/26/01 06:59PM
