I am trying to get a friend's PA50-II to run but am having very little success. The wiring has been pulled out of the headlight enclosure and I am not sure that the wires are connected together correctly. The magneto appears to be generating about 3 volts dc when I pedal the bike and the horn will work while pedaling also. I checked the condenser with my tvm and it appears to be working fine. The primary windings of the coil measured from the points to ground appear to be intact.
When I pedal, there is no spark. If I continuously toggle the kill switch while pedalling, I will get a spark during the transition from kill to run. I cannot find a spot on the switch where I can get continuous spark. Can anyone offer any suggestions or any help with the wiring in the headlight casing?
