I was just curious, I understand that second gear in the two speed is the same ratio as the single speed, but it seems like my single speed goes faster than my two speed, and the two speed is actually geared higher at the sprocket than the one speed. Did Puch make transmissions with different internal ratios or are they all the same and I'm just imagining things? (Side by side at the same speed, it seems like my two speed wraps out in second when the single speed still has another 5 to 10 mph)
The single speed is a 77 Newport (same as Maxi) and the two speed is a 79 Maxi
