Hi all, Is about 200 miles (3 tanks of gas) normal use for a plug? Thats about all I can get out of the ngk's I put into my PA50II. I run 32:1 for a fuel mix. Would a Bosh do me better or is there some basic 2stroke trick I've yet to learn? If I used a hotter plug? (I use a bpr6hs (NGK), gapped at .28). I usually carrie a spare plug, (you do get tied of pushing the darn thing).
Mabey using synthetic oil for the mix? It's a PAIN!
thanks
Rob
