Re: Now I did it!
Michael L. /
Ive never tried a helicoil, but the local chain shops around here (Murrays, Supertrak, etc) all have these fix-a-plug kits. i had to use one on mine. they give you a hardened steel tool that bores out the hole and taps the thread for you. you then choose the proper sized insert and put some hi-temp gasket seal around it and thread it into the hole you made. one of the threads has little teeth and you use a punch tool to expand it so the teeth grab. i had to use one and it worked great. only cost like 7 bucks for the entire kit too. The other solution (the better one) is to find someone who can tig weld and have them fill the hole (kindof a pain in the ass to do with tig) and then drill and tap a new plug hole. you can have a machine shop do it but they'd prolly charge you more than youre willing to pay.
  Now I did it!Topic by: josh josh 06/24/01 11:16PM
  Re: Now I did it!Re: gimmyjimmy gimmyjimmy 06/24/01 11:42PM
  Re: Now I did it!Re: Ron Brown Ron Brown 06/25/01 01:19AM
  Re: Now I did it!Re: Ron Brown Ron Brown 06/25/01 01:22AM
  Re: Now I did it!Re: Brian Allen Brian Allen 06/25/01 01:51AM
  Re: Now I did it!Re: Ron Brown Ron Brown 06/25/01 10:31AM
  Re: Now I did it!Re: Brian Brian 06/25/01 12:01PM
  Re: Now I did it!Re: Ron Brown Ron Brown 06/25/01 12:23PM
  Re: Now I did it!Re: Michael L. Michael L. 06/25/01 02:21AM
  Re: Now I did it!Re: Ron Brown Ron Brown 06/25/01 10:34AM
  Re: Now I did it!Re: Chris Robertson Chris Robertson 06/26/01 10:58AM
  Re: Now I did it!Re: Ron Brown Ron Brown 06/26/01 12:38PM
  Re:they're called..Re: Jim C. Jim C. 06/25/01 11:28PM
  Re:they're called..Re: Ron Brown Ron Brown 06/26/01 12:27PM
