Re: QT50 only goes 20mph?? I need help!
John /
Hi,
this baffles me as well, my qt50 used to toot along at over 30mph bu now i`m lucky if i get mph out of it !, up to now i`ve done the following :-
put new exhaust on
stripped cylinder replaced piston rings
replaced all gaskets
replaced spark plug
topped up battery with water
and you guessed it still no more than 20 mph !!
I think problem could now be in electrics somewhere, I just can`t get the flywheel off to get at them, does the qt have a set of points that can be adjusted ??
if you find out anymore please post, i`m not giving up on this one, i`ll cure it if it kills me !!!
regards
John (Great Britain)
  QT50 only goes 20mph?? I need help!Topic by: Brian Brian 06/23/01 06:24PM
  Re: QT50 only goes 20mph?? I need help!Re: Matt Matt 06/23/01 08:31PM
  Re: QT50 only goes 20mph?? I need help!Re: Shmiver Shmiver 06/24/01 04:48PM
  Re: QT50 only goes 20mph?? I need help!Re: Gavin Gavin 06/25/01 02:17PM
  Re: QT50 only goes 20mph?? I need help!Re: john john 11/15/09 05:48PM
  Re: QT50 only goes 20mph?? I need help!Re: Duane Duane 06/26/01 10:04PM
  Re: QT50 only goes 20mph?? I need help!Re: Brian Brian 06/27/01 12:38PM
  Re: QT50 only goes 20mph?? I need help!Re: BRIAN BRIAN 06/30/01 09:48AM
  Re: QT50 only goes 20mph?? I need help!Re: BRIAN BRIAN 06/30/01 09:49AM
  Re: QT50 only goes 20mph?? I need help!Re: Brian Brian 06/30/01 11:16PM
  Re: QT50 only goes 20mph?? I need help!Re: bryanb bryanb 07/15/01 12:49PM
  Re: QT50 only goes 20mph?? I need help!Re: don-ohio don-ohio 07/15/01 09:35PM
  Re: QT50 only goes 20mph?? I need help!Re: Brian Brian 08/13/01 03:49PM
  Re: I want to buid/buy 6 custom chopped mopedsRe: David M. Becker David M. Becker 08/02/01 05:01AM
  Re: Moped ChoppersRe: David M. Becker David M. Becker 08/02/01 05:05AM
  Re: QT50 only goes 20mph?? I need help!Re: Bill Bill 07/26/01 02:11PM
  Re: QT50 only goes 20mph?? I need help!Re: John John 08/10/01 08:32AM
  Re: QT50 only goes 20mph?? I need help!Re: matt matt 08/19/01 05:46PM
  Re: QT50 only goes 20mph?? I need help!Re: John John 08/13/01 04:30PM
  QT50 only goes 20mph?? I need help!Re: todd todd 08/01/08 10:40PM
  Re: QT50 only goes 20mph?? I need help!Re: David David David David 08/13/08 10:34AM
  Re: QT50 only goes 20mph?? I need help!Re: Jon-O Jon-O 08/02/08 12:19AM
  Re: QT50 only goes 20mph?? I need help!Re: Nick Nick 08/13/08 08:48PM
  Re: QT50 only goes 20mph?? I need help!Re: Scott Scott 08/13/08 10:19PM
