Re: QT50 only goes 20mph?? I need help!
Bill /
Throw a new piston and rings in it. You will probably find the rings are melted to the lans on the piston. Remove the cylider and head to check, you'll need a new cylinder base gasket and should replace the head gasket as well, if you can't find parts then just make a new base gasket and reuse the copper head gasket
  QT50 only goes 20mph?? I need help!Topic by: Brian Brian 06/23/01 06:24PM
  Re: QT50 only goes 20mph?? I need help!Re: Matt Matt 06/23/01 08:31PM
  Re: QT50 only goes 20mph?? I need help!Re: Shmiver Shmiver 06/24/01 04:48PM
  Re: QT50 only goes 20mph?? I need help!Re: Gavin Gavin 06/25/01 02:17PM
  Re: QT50 only goes 20mph?? I need help!Re: john john 11/15/09 05:48PM
  Re: QT50 only goes 20mph?? I need help!Re: Duane Duane 06/26/01 10:04PM
  Re: QT50 only goes 20mph?? I need help!Re: Brian Brian 06/27/01 12:38PM
  Re: QT50 only goes 20mph?? I need help!Re: BRIAN BRIAN 06/30/01 09:48AM
  Re: QT50 only goes 20mph?? I need help!Re: BRIAN BRIAN 06/30/01 09:49AM
  Re: QT50 only goes 20mph?? I need help!Re: Brian Brian 06/30/01 11:16PM
  Re: QT50 only goes 20mph?? I need help!Re: bryanb bryanb 07/15/01 12:49PM
  Re: QT50 only goes 20mph?? I need help!Re: don-ohio don-ohio 07/15/01 09:35PM
  Re: QT50 only goes 20mph?? I need help!Re: Brian Brian 08/13/01 03:49PM
  Re: I want to buid/buy 6 custom chopped mopedsRe: David M. Becker David M. Becker 08/02/01 05:01AM
  Re: Moped ChoppersRe: David M. Becker David M. Becker 08/02/01 05:05AM
  Re: QT50 only goes 20mph?? I need help!Re: Bill Bill 07/26/01 02:11PM
  Re: QT50 only goes 20mph?? I need help!Re: John John 08/10/01 08:32AM
  Re: QT50 only goes 20mph?? I need help!Re: matt matt 08/19/01 05:46PM
  Re: QT50 only goes 20mph?? I need help!Re: John John 08/13/01 04:30PM
  QT50 only goes 20mph?? I need help!Re: todd todd 08/01/08 10:40PM
  Re: QT50 only goes 20mph?? I need help!Re: David David David David 08/13/08 10:34AM
  Re: QT50 only goes 20mph?? I need help!Re: Jon-O Jon-O 08/02/08 12:19AM
  Re: QT50 only goes 20mph?? I need help!Re: Nick Nick 08/13/08 08:48PM
  Re: QT50 only goes 20mph?? I need help!Re: Scott Scott 08/13/08 10:19PM
