1988 Suzuki starting problem
Robert Bentzel /
If any one can help with this I would be greatfull. I have a problem with cold starting this moped. When you first try and start it with the choke in it will run for a few seconds and then shut off. You have to go through this about 15 times then it will finally start and run with no problems. The bike can be shut down and restarted also with no problems. However if you leave it sitting for 30 minutes or so. It again is very hard to start Any help would be appreciated.
Thanks,
Robert
Re: 1988 Suzuki starting problem
Robert Bentzel /
By the way it is a fa50 fa 50.
Robert
1988 Suzuki FA50 starting problem...HELP THIS GUY
It is probably a dirty carburetor, but it might be starving for gas,and the excess pull of the choke gets a little gas to go in.
Those buggers have a different type of fuel valve that might cause a problem too. Are you sure you have the fuel valve set to the proper position? Maybe someone that knows FA50s will answer? Anyway...I'm guessing a lack of fuel or a dirty carb. don-ohio
