Re: Yamaha Starting Update
Ron Brown /
Josh,
Good post.
You explain that when the ped died the first time, a new plug would show a good spark until you installed it, then get wet and quit sparking. This was almost certainly too rich. 2 cycles can foul a plug faster than you can change it when they are too rich. The second time it died, you mention that the plug was a nice grey color. Was it wet and did you then have the same symptoms you had after the first failure?
I think Fred is on the right track. If you have dirt traveling through the carb, when it sticks to the needle valve you run rich and if it travels to the main jet you run lean or stop.
Keep us posted,
Ron
  Yamaha Starting UpdateTopic by: josh josh 06/23/01 02:19AM
  Re: Yamaha Starting UpdateRe: don-ohio don-ohio 06/23/01 09:54AM
  Re: Yamaha Starting UpdateRe: josh josh 06/24/01 05:37PM
  Re: Yamaha Starting UpdateRe: don-ohio don-ohio 06/24/01 05:59PM
  Re: Yamaha Starting UpdateRe: Chris Robertson Chris Robertson 06/23/01 11:36AM
  Re: Yamaha Starting UpdateRe: Jim C. Jim C. 06/23/01 11:57AM
  Re: Yamaha Starting UpdateRe: Gavin Gavin 06/23/01 01:29PM
  Deja VuRe: Fred Fred 06/23/01 01:49PM
  Re: Deja VuRe: josh josh 06/24/01 12:40PM
  Re: Deja VuRe: don-ohio don-ohio 06/24/01 01:05PM
  Re: Deja VuRe: josh josh 06/24/01 05:16PM
  Re: Deja VuRe: don-ohio don-ohio 06/24/01 05:24PM
  Re: Deja VuRe: Ron Brown Ron Brown 06/25/01 12:48AM
  Re: Deja VuRe: Ron Brown Ron Brown 06/25/01 12:49AM
  Re: Yamaha Starting UpdateRe: Ron Brown Ron Brown 06/23/01 09:18PM
  Re: Yamaha Starting UpdateRe: nick nick 06/25/01 12:53PM
