Deja Vu
Fred /
It sounds like you are getting too much fuel.
Are you sure the choke is in the correct position ??... (as in ..OFF.. after it warms up?)
Next...
You MUST install an inline fuel filter.
You MUST carefully inspect the float needle valve (in the carb) for wear on its tip and bits of crud letting in too much gas...
You MUST blow high pressure compressed air through the fuel inlet to the carb .. both ways.. after removing the float and needle..
Is the main jet still in the carb? (nobody lost it before you got it?)
Then... clean the air filter in gas (don't oil the filter yet though).
All those checks and fixes are to make sure it isn't getting too much fuel.
Then put a new spark plug in and leave the air filter off temporarily and start it and ride it and pay attention to how it is running.. run it for a half an hour and check the plug color. .
(if you live on a dusty dirt road... make sure that dust isn't going into the carb.. if it is.. you should put the air filter on for the test)
Try all that.
  Yamaha Starting UpdateTopic by: josh josh 06/23/01 02:19AM
  Re: Yamaha Starting UpdateRe: don-ohio don-ohio 06/23/01 09:54AM
  Re: Yamaha Starting UpdateRe: josh josh 06/24/01 05:37PM
  Re: Yamaha Starting UpdateRe: don-ohio don-ohio 06/24/01 05:59PM
  Re: Yamaha Starting UpdateRe: Chris Robertson Chris Robertson 06/23/01 11:36AM
  Re: Yamaha Starting UpdateRe: Jim C. Jim C. 06/23/01 11:57AM
  Re: Yamaha Starting UpdateRe: Gavin Gavin 06/23/01 01:29PM
  Deja VuRe: Fred Fred 06/23/01 01:49PM
  Re: Deja VuRe: josh josh 06/24/01 12:40PM
  Re: Deja VuRe: don-ohio don-ohio 06/24/01 01:05PM
  Re: Deja VuRe: josh josh 06/24/01 05:16PM
  Re: Deja VuRe: don-ohio don-ohio 06/24/01 05:24PM
  Re: Deja VuRe: Ron Brown Ron Brown 06/25/01 12:48AM
  Re: Deja VuRe: Ron Brown Ron Brown 06/25/01 12:49AM
  Re: Yamaha Starting UpdateRe: Ron Brown Ron Brown 06/23/01 09:18PM
  Re: Yamaha Starting UpdateRe: nick nick 06/25/01 12:53PM
