Re: Yamaha Starting Update
Chris Robertson /
Hi Josh:
<ol>
<li>Are these spark plugs you are using <i>brand new</i>? Are you using the right kind?</li>
<li>You said that cleaning your carburetor fixed the problem the first time and then after 3 hours it stopped working again. Have you cleaned the carburetor again? If your tank is dirty/rusty, it can clog your carburetor up very quickly.</li>
<li>Is it possible your petcock is bad? I've seen them go intermittent where fuel will flow fine for a few hours, then barely come through, and then flow correctly again... The next time your moped dies on you, disconnect the fuel line from the carburetor and verify you are getting a decent fuel flow.
<li>If you've ever removed your flywheel you'll know what the key is: it's a little notch on the crankshaft that fits into a little groove on the flywheel that prevents the flywheel from getting "out of sync" with the engine.</li>
</ol>
Good luck!
Chris.
  Yamaha Starting UpdateTopic by: josh josh 06/23/01 02:19AM
  Re: Yamaha Starting UpdateRe: don-ohio don-ohio 06/23/01 09:54AM
  Re: Yamaha Starting UpdateRe: josh josh 06/24/01 05:37PM
  Re: Yamaha Starting UpdateRe: don-ohio don-ohio 06/24/01 05:59PM
  Re: Yamaha Starting UpdateRe: Chris Robertson Chris Robertson 06/23/01 11:36AM
  Re: Yamaha Starting UpdateRe: Jim C. Jim C. 06/23/01 11:57AM
  Re: Yamaha Starting UpdateRe: Gavin Gavin 06/23/01 01:29PM
  Deja VuRe: Fred Fred 06/23/01 01:49PM
  Re: Deja VuRe: josh josh 06/24/01 12:40PM
  Re: Deja VuRe: don-ohio don-ohio 06/24/01 01:05PM
  Re: Deja VuRe: josh josh 06/24/01 05:16PM
  Re: Deja VuRe: don-ohio don-ohio 06/24/01 05:24PM
  Re: Deja VuRe: Ron Brown Ron Brown 06/25/01 12:48AM
  Re: Deja VuRe: Ron Brown Ron Brown 06/25/01 12:49AM
  Re: Yamaha Starting UpdateRe: Ron Brown Ron Brown 06/23/01 09:18PM
  Re: Yamaha Starting UpdateRe: nick nick 06/25/01 12:53PM
