Re: starting problems... diagnose?
Pumapimp1 /
I took small gas engine shop, and most of the time, after checking all possible suspects in this problem, that little key that holds the flywheel to the crankshaft journal is severely damaged. It could be the points too, but i can't help ya there, I only dealt with mostly solid state magnito ignition systems. good luck!
-pumapimp
  starting problems... diagnose?Topic by: Justin Justin 06/20/01 09:11PM
  Re: starting problems... diagnose?Re: Chris Robertson Chris Robertson 06/20/01 09:46PM
  Re: starting problems... diagnose?Re: Rob Hoehn Rob Hoehn 06/21/01 02:36PM
  Re: starting problems... diagnose?Re: don-ohio don-ohio 06/22/01 03:07PM
  Re: starting problems... diagnose?Re: Pumapimp1 Pumapimp1 06/23/01 02:07AM
  Re: starting problems... diagnose?Re: ivan ivan 07/06/01 01:45AM
