Puch MKII transmission.
XBrandon EdgeX /
All I really need to know is what kind of oil and how much (I'm guessing until it runs out the little filler hole in the side, but if someone could confirm this for me that would be cool) in a Puch two-speed automatic transmission? If anyone knows, your help is deeply appreciated.
It's a 1979 Maxi if that's important.
Thanks,
XBrandon EdgeX
Re: Puch MKII transmission.
Miniengine /
Brandon,
You want to use type F automatic transmission fluild and you are correct on how full to fill it. Just fill until it runs out the fill hole on the side.
Brian
Lamborn's Miniature Engines
http://www.geocities.com/miniengine
XBrandon EdgeX /
Cool, thanks. It looks like the guy who I bought it from filled it with regular motor oil and he filled it way above the fill plug. I've got work to do :). Should I take it apart and clean everything or just run a couple of the right measurements of trans fluid through it?
Just flush it a couple of times and it should be ok.
XBrandon EdgeX /
Rokken! Thanks, guys.
MK II spark plug?
What kind of spark plug does the MK II take?
