Re: big borein'!!!
Roberto /
Mike,
You need to advance the timing when putting on a large bore kit. It should have instructions on what the timing should be (something around 2 degrees advanced I imagine). Also, I would NEVER trust the timing marks on the stator. They are rarely correct. Do it yourself to make sure. The timing not being correct will make your engine backfire and you run the possibility of blowing a hole in the piston. Tootaloo.
  big borein'!!!Topic by: mike mike 06/17/01 12:18AM
  Re: big borein'!!!Re: Reeperette Reeperette 06/17/01 05:57PM
  Re: big borein'!!!Re: mike mike 06/17/01 10:10PM
  Re: big borein'!!!Re: mike mike 06/17/01 10:13PM
  Re: big borein'!!!Re: Daniel Tisone Daniel Tisone 06/17/01 11:33PM
  Re: big borein'!!!Re: Ataristyle Ataristyle 06/18/01 02:15PM
  Re: big borein'!!!Re: mike mike 06/18/01 11:23PM
  Re: big borein'!!!Re: Reeperette Reeperette 06/25/01 01:41PM
  Re: big borein'!!!Re: XBrandon EdgeX XBrandon EdgeX 06/25/01 02:08PM
  Re: big borein'!!!Re: Dan Tisone Dan Tisone 06/25/01 04:32PM
  Re: big borein'!!!Re: Roberto Roberto 06/18/01 05:29PM
  Re: big borein'!!!Re: Dan Tisone Dan Tisone 06/25/01 04:33PM
