Re: Fender Clearance (Re: Tires)
Reeperette /
I went out and looked today...there are four bolts holding it to the forks, and two to the axle...you can loosen those a bit, and then remove the four on the forks, and raise it up so it only uses two.
Only problem with that, is where the fender attachments will be, you'll have to pull the fender to adjust the brakes.
-Ree
  Fender ClearanceTopic by: Wayne Broderick Wayne Broderick 06/15/01 11:33PM
  Re: Fender ClearanceRe: Ben Ben 06/16/01 12:43AM
  Re: Fender ClearanceRe: don-ohio don-ohio 06/16/01 01:32AM
  Re: Fender ClearanceRe: Reeperette Reeperette 06/16/01 01:43PM
  Fender Clearance, High beam (blue bulb)Re: Wayne Broderick Wayne Broderick 06/16/01 02:45PM
  Fender Clearance (Re: Tires)Re: Wayne Broderick Wayne Broderick 06/16/01 02:47PM
  Re: Fender Clearance (Re: Tires)Re: Reeperette Reeperette 06/17/01 11:27PM
  Re: Fender Clearance, High beam (blue bulb)Re: Reeperette Reeperette 06/16/01 09:31PM
  Ree, a Carb Question--for BiTurboRe: Wayne Broderick Wayne Broderick 06/16/01 11:12PM
  Re: Ree, a Carb Question--for BiTurboRe: derek derek 06/17/01 02:06AM
  Re: Ree, a Carb Question--for BiTurboRe: Reeperette Reeperette 06/17/01 05:51PM
