Re: Ree, a Carb Question--for BiTurbo
Reeperette /
Put a #56 jet in it.
I think stock is a #51 in a Targa...and if you just slam a BiTurbo on there. get a #54 and a #56, put the #56 in, and if it runs good, ok...if it's just a little rich (four strokes, etc) - try the #54.
BT tends to lean it out a bit, so go really easy on it.
You might also wanna up your oil intake by an extra 1/2oz per gallon.
And I checked the wir a minnit ago...the WHITE wire goes to the very center clip in the back of the headlight...the one hanging loose should have two GREY wires goin into the clip.
Hope that helps some,
-Ree
  Fender ClearanceTopic by: Wayne Broderick Wayne Broderick 06/15/01 11:33PM
  Re: Fender ClearanceRe: Ben Ben 06/16/01 12:43AM
  Re: Fender ClearanceRe: don-ohio don-ohio 06/16/01 01:32AM
  Re: Fender ClearanceRe: Reeperette Reeperette 06/16/01 01:43PM
  Fender Clearance, High beam (blue bulb)Re: Wayne Broderick Wayne Broderick 06/16/01 02:45PM
  Fender Clearance (Re: Tires)Re: Wayne Broderick Wayne Broderick 06/16/01 02:47PM
  Re: Fender Clearance (Re: Tires)Re: Reeperette Reeperette 06/17/01 11:27PM
  Re: Fender Clearance, High beam (blue bulb)Re: Reeperette Reeperette 06/16/01 09:31PM
  Ree, a Carb Question--for BiTurboRe: Wayne Broderick Wayne Broderick 06/16/01 11:12PM
  Re: Ree, a Carb Question--for BiTurboRe: derek derek 06/17/01 02:06AM
  Re: Ree, a Carb Question--for BiTurboRe: Reeperette Reeperette 06/17/01 05:51PM
