Fender Clearance, High beam (blue bulb)
Wayne Broderick /
Ree... I've got a lot of hardware stores nearby-- I don't want to lose my fender, but I would like to see thaqt 1/2 inch you're talking about. What should I look for? I know what a spacer is, but I'm triying to picture what I'll need to do.
Picturing it in my head.. "....a couple of bolts up on the top center of the fender-- those bolt it to the forks... Then there's the sort of 'tripod' support rods that connect to the axle for support....."
Am I going to be spacing near the axle, or the bolts, or both.. I saw some holes a little higher on the forks, but I always thought those were for a rack.
Another Issue-- I lost my little blue high beam light. Either the bulb popped or the connection came off. I was looking up under there (without taking off the cowling) and theres a single white wire, not connected to anything. All my other lights work fine.
Ree: Do you know if there is an extra white wire up under there? No hurry to fix, just doing the homework ahead of time.
Thanks as always-- You guys are great!
  Fender ClearanceTopic by: Wayne Broderick Wayne Broderick 06/15/01 11:33PM
  Re: Fender ClearanceRe: Ben Ben 06/16/01 12:43AM
  Re: Fender ClearanceRe: don-ohio don-ohio 06/16/01 01:32AM
  Re: Fender ClearanceRe: Reeperette Reeperette 06/16/01 01:43PM
  Fender Clearance, High beam (blue bulb)Re: Wayne Broderick Wayne Broderick 06/16/01 02:45PM
  Fender Clearance (Re: Tires)Re: Wayne Broderick Wayne Broderick 06/16/01 02:47PM
  Re: Fender Clearance (Re: Tires)Re: Reeperette Reeperette 06/17/01 11:27PM
  Re: Fender Clearance, High beam (blue bulb)Re: Reeperette Reeperette 06/16/01 09:31PM
  Ree, a Carb Question--for BiTurboRe: Wayne Broderick Wayne Broderick 06/16/01 11:12PM
  Re: Ree, a Carb Question--for BiTurboRe: derek derek 06/17/01 02:06AM
  Re: Ree, a Carb Question--for BiTurboRe: Reeperette Reeperette 06/17/01 05:51PM
