Hi! There is probably a brake lever return spring broken.It might be on the outside of the hub like most old `peds.If that,s not it it might be your cable sticking or the internal brake components corroded or broken.But look for the external brake lever return spring first.Most `peds have one on the front also so look at your front wheel and see if anything's missing.BYE!
