Re: sucky brakes continued
Ron Brown /
Mike,
It sounds like you have done almost everything to get your brakes working, I suspect that the forward/backward thig is more perception that real. Peds are easier to push forward anyway.
Ped brakes are "single leading shoe" brakes, which means they exert the same braking force going forward or backward. "Double leading shoe" brakes are the ones that don't work going backwards.
On to your problem. I wonder where the shiny black comes from on your shoes. Abresive action on steel, which is what your brake drums are lined with, does create black stuff. But it does not sound like you have had enough braking action to do this.
Have you cleaned the inside of the drum and the shoes with brake cleaner until a paper towel comes away clean?
If this is true, then the only thing left is pad shoe material. I don't know what you have done so far, you may have to refresh me.
Ron
  sucky brakes continuedTopic by: mike mike 06/13/01 10:51PM
  Re: sucky brakes continuedRe: Ken Ken 06/13/01 11:09PM
  Re: sucky brakes continuedRe: Reeperette Reeperette 06/14/01 07:33AM
  Re: sucky brakes continuedRe: Ron Brown Ron Brown 06/14/01 04:03PM
  The reason why they are sucky brakes is because thRe: BHP BHP 06/14/01 11:58PM
  Re: sucky brakes continuedRe: don-ohio don-ohio 06/15/01 02:09AM
  Re: sucky brakes continuedRe: Doug D. Doug D. 06/15/01 01:52PM
  Re: sucky brakes continuedRe: derek derek 06/17/01 03:17AM
  Re: sucky brakes continuedRe: mike mike 06/17/01 10:27PM
