I need a part.
Bill Featherstone /
I have a Derbi SLE Variant, vintage 3/1983, that I just got out of storage after several years of non-use. In fact, it has hardly been used, with only about 300 original miles registering on the odometer. I bought it brand-new. A friend of mine took the carburetor apart to clean it, and when he put it back together, it leaked fuel through the screw-down cap on top of the carburetor when running. Obviously, that has to be fixed. I think the cap on the carburetor needs to be replaced. Sorry for the lack of proper phraseology in regard to the part, but I'm definitely no mechanic. Anyway, does anyone know where I can get a part for my moped? All I need is this one little part to the carburetor, and I'm off and running again. The moped is in beautiful shape, and begging to be ridden. Thanks, Bill P.S. How do I establish a value on my moped? Is there a credible service that establishes values on older mopeds?
Re: I need a part.
Reeperette /
Interesting that I might, by chance...know EXACTLY what's wrong with it....given that I made an at least similar mistake yesterday.
Check and see if yer friend put the float in upsidedown (Doh!)
Cause that's one screwup I made yesterday, with the exact same results you describe.
-Ree
Re: I need a part.
Chris Robertson /
You might also want to make sure that the gasket on the part that screws onto your carburetor is both still present, and in good shape.
Chris.
Re: I need a part.
All you need is a new gasket. Any Delorto float bowl gasket will work, and in a pinch you can just get a round gasket and squish it into the proper shape, we
