Ron,
LOL I don't wear my emotions on my shirt sleeves so your okay on this end Ron. It would take more then a few words to desolve the friendship we've made over the last weeks.
Now you want to talk about dummies. I almost had the Batavus sealed bearing modification for the hub ready for post when I caught myself about to make a mistake. I made a spacer tube for between the bearings that the treaded rod axle would slide through and then discovered that if I assembled it as is, that I would have no way to disassemble it. The solution was to make a treaded tube so you could hammer on the treaded rod to knock one set of bearings out. I asked myself why on God's green earth would Batavus use a treaded rod axle that was 12mm-1.0mm. I can't find taps let alone nuts to fit this thread. It must be a bicycle standard. So in a scramble to denounce my dummy status I'm using 12mm-1.75mm threaded rod. I should have this project completed by this coming weekend. Next on the list will be the shaving of the Batavus head.
If it ain't broke, you're not trying hard enough.
Brian
Lamborn's Miniature Engines
