Re: how to fix rear brakes? and other puch issues
miguel /
brandon:
thanks. i'll look at the brakes tomorrow. what should i look for? how do i adjust the brake pads if they're just not grabbing right?
also, on the throttle cable. i put the assembly together myself. it's going backwards because that was the only way i could put the cable in. i can't get the cable end out of the carb, and had to go through that side. i put the cable in through the little hole and then it stuck in there. i think i put it in backwards? i can try to get it right w/ some practice. i hope i can ....
i'll work on the on/off switches. i have some, but i'm trying to find out which one grounds out quickly ... but trial and error is a surefire way ... in the long run.
i'll post again tomorrow after i hit another brick wall. any other opinions welcome. thanks.
