What is the right kind? The moped itself says use ATF trans fluid, someone's manual says use type-F, and my brother says that Mercon III Dexron should work in just about everything. Here's what I've concluded from reading the bottles:
ATF+ is for Chrysler transmissions
Type-F is for certain Ford transmissions
Mercon III Dexron is for Chevrolet, Chrysler, and most others, including Daimler-Benz (who actually owns Puch) and does not work in Fords.
So what my moped says to use and what one of the forum user's manual says to use are two completely different fluids for very different transmissions.
Would the real correct fluid please step forward...
Oh yeah, it's a 1977 Puch Newport (same as Maxi) Single speed transmission.
I deeply appreciate any help.
